Good day all,
Looking at different options for the steering column and would like to know if the following two options are what you guys are typically using in the neck, any thoughts would be appreciated, Thanks
Would this type of flange bearing work? 5/8" ID x 1-3/8" OD x 5/16" Thick Standard Ball Bearing with Flange
Or if going with bushings would this work? Bronze Bushing 1/2" Shaft Diameter 5/8" OD 3/4" Length
