Stretched DB 30
#22
I dropped the frame off at the powder coating shop yesterday. It should be ready on Friday. I decided on satin black for the color as it will help mask any imperfections in the frame, whereas gloss black would have enhanced them. I also ordered 13x5-6 slicks for the front and rear, as well as 6 feet of #35 chain. Stay tuned for more updates.
#24
Max, any updates on your Project? :smile:
Not yet, I thought I would have the frame back from the powder coater last Friday. However, when I called to see if I could pick it up, the guy said he was a little behind in his work orders and probably wouldn't have it finished before Wednesday or Friday of this week. I will post pics as soon as I get it back.
#26
I picked up my DB frame from the powder coating shop today. I am not 100% satisfied wth the quality of work, but it will have to do. I will try and start the assembly process tomorrow, if my schedule permits. Here are a few pics.
minidragbike
Supporting Speed Nut!
#31
LOL! Are you gonna stretch your DB too? You are right about the tank being expensive. It was a new tank though.
I don't think I am, but I was seriously thinking about it at one time.
Yeah those tanks cost a good amount. I have a couple of large 1 gallon versions, and a 2 quart black fiber glass drag one. I like to keep them as spares.
#34
Looking good Max. :thumbsup::thumbsup: What is the little tank on the back going to be used for? :thumbsup: :smile:
That is an oil catch tank. It is connected to the valve cover and will relieve crankcase pressure, while catching any oil mist that might blow by.
#36
Put the brand new wheels/tires on today. Unfortunately, the treads don't match, but that's alright, because the tires probably won''t last long anyway. I also cut the chain to the correct length last night. FYI for those considering stretching their DB, you will need a chain that has 180 pins for a 5 inch stretch.
#37
Its Looking Pretty good there Max. I'm thinking about stretching my mini bike but I don't know the first thing about how to do it all. :thumbsup: :smile:
MiniBike Paul
You are doing a nice job! 3 questions; How potent is that motor? Why did you stretch it (the frame)?? Are you going to run the chain direct, without a jackshaft??
#39
Thanks! The motor has the following mods: Governor removed, ported/polished and milled nead (.055), billet rod, Honda aluminum flywheel, stock stainless steel valves, 18# springs, aluminum valve retainers/keepers Honda flat top piston, .265 modified cam, chrome molly pushrods, and a Tilly 304WX (gas carb).
I stretched the frame to help keep the front end from coming up and I also liked the look. Yes, I am going to run the chain without a jackshaft kit. I will have to make sure everything is aligned well, so that I can hopefully avoid any chain issues.
