Doing what I can to make this thread as informative as possible. I'm kinda learning as I go on some of this stuff. I'm thinking I might go with a tiliston carb instead of the flat slide mikuni.
I ordered 2 .045 fiber head gaskets with fire rings for a 3" bore. I also got a can of copper gasket sealer spray to seal the gaskets together. I figured if there are any imperfections in the head or block deck the fiber would seal them better then the copper. Gaskets were $25 a piece and the sealer was $12 from nr racing.
My carb came in a week ago haven't bolted it on yet or fired the motor yet been busy working on a chassis for it. Just need a few pieces and the chassis will be ready. Here's the carb and a mock up of the chassis.
Well I finally fired the motor, I put a 22mm mikuni on it and ran 2 heat cycles on gas and the bolted on the Tillotson and ran a heat cycle on methonal.
Stroker motor final heat cycle, on methanol.: https://youtu.be/6rexeKEgEP0
