I almost cringe at posting this, with all the misc oil threads, but here goes...
I use the "cheap" Walmart synthetic 5W-30 in almost all of my small engines, because they are almost all Briggs, and Briggs lists 5W-30 synthetic as one of the best options for their motors.
Oil Recommendations | Briggs & Stratton
I've never thought about break-in on small engines before (oops), but none of my small engines got synthetic until they had run at least for a few hours, anyway.
The Predator 212 manual does not mention use of synthetic. Can/should I use 5W-30 in this engine, too, presumably after the break-in period?
I read a lot of threads and now I'm spooked with all the comments about this or that additive not being used any more in cars and the small engines needing that additive; or details about how the engine should be broken in. Geez, it seems so complicated.
I figured to do this. This is not for a "performance" bike. I'm not going to mod the engine.
-- Drain whatever oil is in the new engine. I have no idea what is in there, except it's slippery.
-- Put in 10W-30.
-- Run it for 10-15 minutes on idle, let it cool, run it for 10-15 minutes at low-medium loads, let it cool, then run it normally for the remainder of the break-in period, without revving it too high (but max is 3600 rpm, anyway), or loading it too heavily.
-- Change the oil after the 3-hour break-in period, replace with 5W-30 synthetic.
Anything else? Different? Thanks...
-- Put in 10W-30.
