Hey GTO, how's that ST-100. I thought you'd have it finished over the holidays.
I'm still waiting for a repair on one half of my back rim. Rims looked fine from outside, but I had to cut the tire off because of the rust scale inside the rim. Pitting was so bad there was one pinhole that grows every time my welder friend tries to add metal. These are not the same as the Honda Z 50 wheels, but are just like the Gemini 50 wheels with the integral brake drum and the sprocket mount. Needles to say I haven't found a single useable replacement part on e-bay or the internet in months. At worst, I can cut out the center disk from the wheel rim and use with some Z 50 wheel halves, but the number of bolt holes and cutouts will be a mismatch. The rest is esentially ready to reassemble. I have the frame and all other parts painted, Hs-40 running and ready, chrome shined, all new wheel and jack shaft bearings ready to install. Will just need a new Taco seat cover and chain guard, but I'm saving up for those!
I have seen some Gemini parts and located some forks for Tom be he keeps sidetracking on how they fit. :thefinger:
The rear wheel is hard to find and I've yet to see anything with the same sprocket mount.
As for the hole try less heat or make a patch out of metal them tack the hole. :thumbsup:
As for my Taco, it's pretty much done and I just need a kick in the pants.
