thanks!!!!!! I once had a china scooter that would not start cold but would run and start fine hot ....changed the carb ect turned out to be a vale adj....the book says you could use a vee block to my sander to the stem ....this maybe the issue..... valve timing looks funny also....also I need to check what valves are in the correct seat
