Hello All,
I need some help and advice from the masters on this page. While I am not a novice when it comes to small engines, this is the most in depth I have gone working on one.
Here is what's up: I got this 70s ARCO E-Z Rider from my mother in law 13-ish years ago. It is a H30 -35176J - The story I was told is that is has always been hard to start and get going. I finally decided to mess with it as a COVID Isolation project, but am having trouble getting it to start.
-- I have changed: points, condenser, coil, plug -(all by the book to spec)
-- I have pulled the Head, cleaned, replaced with a new gasket, torqued to spec. (valves look good, has compression)
-- Rebuild the carb with a carb kit
-- New gaskets on both sides of the carb and exhaust, new gasket in the valve breather assembly
-- I have timed it as close to .065 BTDC (book specs) as I can - I am using feeler gauges and a continuity tester (volt/ohm meter)
-- The key in the flywheel is not sheared or appear defective
-- Inside the fly wheel is clean, coil steel pack is clean
When I try to start, with main jet and Idle jet set to "factory settings", I can get it to Hick-up and gurgle like it WANTS to start, but I can not get any sort of actual slight running. I have tried starting fluid and that does not do anything either. No backfires, no BLACK smoke, but a little wispy white WHITE smoke, look like it is from the valve breather opening?
I have spark (checking by grounding plug to head) - I am getting a little smoke when it does try to start, so I am assuming I am getting fuel in.
My assumption is that it is either 1) My timing is not accurate enough to get it to fire. 2) My carb is shot and just too worn out. 3) There is a bigger issue, maybe in the crank case?
Any help, advice or guidance would be much appreciated. I am almost ready to take it in and have someone else work on it, but what's the fun in that? I
Thank you,
Caveman
Thank you,
Caveman
