H50 crank shaft in the front and H60 crank shaft in the rear . You can see how the rear rod journal was opened up to.970 width and you guys with eagle eyes can see the rear rod journal is turned down to .998 . I have to admit that these guys at Crankshaft Craftsmen did an excellent job and there numbers were dead on .
One of the billet rods beside the stock H50 rod .
Rod bearings from ARC , 6392 and a 6392-0 . Locked up one billet rod in the vice to measure bearing clearances installed rod cap and bearing and torqued them down , Installed each set of new bearings the same way and the 6392 came out with .003 clearance and the 6392-0 came out at about .005 to.006 . Went back with plastigage and rechecked and came out with the same numbers .
6392 : .003
6392-0 : .005 to .006
Sorry all pics did not come out good, so you'll have to trust me on the numbers. Hard to hold a rod cap , plastigage and take a pic at the same time ...:laugh: I will be using the 6392 bearing on this build.
Block has been cleaned and slightly honed for the moment. Dry run on installing the rod and piston, everything looks good at this point.
Up next will probably be the porting , doesn't look real bad Tecumseh did a nice job on these stock ports .
Cam specs , hard numbers are .278 exh and .267 Int . Not sure why the Exh. numbers are higher than the Int. Don't think theres a compression bump on the Exh . But will be doing some more checking though.
Valves measure out the same diameter at 1.155 or about 29mm , not sure why that is either.. Exh. is usually smaller than Int. on most engines.
