Let's set the record straight....the original pics of the broken rod were mine and were plagiarized. The broken rod was in a NOS H70 that had been turned up. The failure occurred due to lack of oil when running 5000rpm and above....that is why any engine I own capable of 5000+ rpm get synthetic oil. I have yet to have a failure once using synthetic. That broken rod actually broke at 6800rpm and if you had noticed it was blue due to heat/lack of lubrication due to using standard 30wt oil.
It will not matter what your material your rod is made from if it is not oiling at the crank or wrist pin it will fail!
