I say the exact same thing.. Also if you can get a bolt threaded down into the crank nice and deep and tight, you can use that for whacking purposes.. Just a slight not even dangerous smack, added to your pickle fork contraption, ads an exponential amount of break-loose-tion to the mechanics of it all.. that fast shocking energy being delivered to the crank sends shock waves through the parts..
So, you can smack a bolt and that helps.. If you do everything to the point of ("I'm going to break something") :hammer: Then just STOP!! and leave the fluids to do their magic..
I'd definately get that plug out of the sheve boefore trying to move it at all..
Heat... :weld: The steel tube and iron crank being one piece, it's all gonna heat pretty evenly, which ya don't want.. Heating the sheeve makes it swell to a larger size, so it's looser, swelling the crank just makes it worse..
if ya can flash heat it real quick run around it all with the torch doing tearups, it might help..
I would just heat it all to beat hell and let it cool back off a few times.. Then dump your fluids back in to soak overnight, and try it all again..
