I tore the mystery west bend powered bike down today and am going to start redoing it. Still have no idea who made it but after the teardown I feel this was not a mass produced bike. It very well may have been a Prototype, or maybe a technical school/college project, who knows:shrug:
I was able to get the bike to start within 2 pulls once I got some fuel in the carb. I got it to run briefly even though everything is gummed up. As far redo goes everything is in working order, just all needs detailed, cleaned etc..
Heres where it starts:
it came apart easy thanks to alot premix buildup all over it :thumbsup: the whole time I was trying to find any indication of builder, or at least something to sort of date the bike.
Marking on front wheel (6")
Bendix rear brake/sprocket assy (this has been welded to the rear hub assy and rear wheel does not match the front)
I've never seen a master link like this one, I thought it was cool:
the motor tag:
Fuel cap has a cork that holds it in the fiberglass underseat tank:
Disassembled in half an hour:
Getting a better look at the bike they slugged the frame in spots for strength, some things were brazed and some things you can tell they improvised while building. Nothing other than one handlebar has been altered after completion.
I did find one small crack in the frame that I need to address:
Thats it so far, Most of the paint is just flaking right off, so a good cleaning an then I will do some blasting and repairing. Hard part will be the tank, it has some leaks and will need some attention. Worst case I guess I can run a small round tank on it, who's gonna tell me its incorrect:thefinger: Of course if someone can come up with the origins of this bike.....................:bowdown:
the motor tag:
