When using the original throttle control on a Predator or Honda clone you can add a second return spring as seen here:
(click to enlarge)
If you've loosened up the retaining nut and/or removed the friction washer and still find you need a little more help to pull the cable back, this will do the trick. Adding a second return spring also serves as a back up and provides a more positive response from the twist grip throttle control.
It only requires drilling a 1/16" hole in the assembly base and the other end can then be attached to the cable anchor as seen in the photo above.
The spring seen here is one that I got from Lowes. A similar sized spring available at any hardware store would work just as well. It's the right size and weight for a stock Predator/clone application.
This is just one way to do it. If you've found a way to add a return spring to the throttle control please describe what you did and share a photo of how you mounted it, here.
(click to enlarge)
