Here is a photo of my Briggs 2hp that came on my Bonanza. It is a 1987 motor, model 60102. It arrived with the big return spring coming off a head bolt, obviously wrong. What is the correct set up for the return spring? It looks like there could have been a spring that wraps around the throttle itself and the small bracket it pivots on, judging by the shape of the bracket and small hole at the bottom front of it. I could also try and get a spring that goes around the throttle cable and pushes the throttle back with one end of the spring against the screw/washer that is hold the throttle cable in place and the throttle itself. Any help appreciated...And I have a new throttle cable on order where the housing will be a little further back towards the lock screw with a little more of the cable itself exposed.
