2hp
  1. C
    What oil weight should I use in a 1958 2HP B&S
    What oil weight should I use? I'd like to run synthetic as well.
  2. R
    Throttle Return Spring Question...Briggs 2hp
    Here is a photo of my Briggs 2hp that came on my Bonanza. It is a 1987 motor, model 60102. It arrived with the big return spring coming off a head bolt, obviously wrong. What is the correct set up for the return spring? It looks like there could have been a spring that wraps around the...
  3. Racer
    Briggs and Stratton 2hp No Spark
    Minibikers It sat for one year and started before that. It's a Model 61200. How do you determine whether there are points under the flywheel? There's a kill switch wire running into general area. Have shroud off. Will track down kill switch wire. Why is kill switch wire bare no...
  4. jackeo21
    2HP Restoration/Hot Rod
    Good evening folks, It's been quite some time since my last restoration thread so I've decided to make a little comeback :thumbsup: The Candidate: A 1969 Briggs and Stratton 2HP, with a vaccu-jet carburetor and 5/8" crankshaft The Plan: To make a tough, reliable engine that looks better...
  5. A
    I need to drill and tap crank Briggs 2hp
    my nephews kids have a doodle bug that killed a 97cc and I want to replace it with a 2hp from an old edger but the crankshaft needs to be drilled and tapped. Being the tightwad that I am is this something I can do myself with a hand drill and Harbor Freight tap and die set? I can't even...
  6. D
    More hp from 2hp
    How to make more from a 2hp. Carb for a start?
  7. J
    Cute little 2hp briggs
    I picked up a 2hp briggs on a small rototiller today at a garage sale for $15. Did these little engines ever come on any minibikes? I dunno if they are worth anything, but the thing was so damn cute I had to buy it.
  8. weldkingoc
    Vintage briggs and stratton external dimension 2hp vs 3hp
    Since i dont have one here to measure i was curious if the outside overall height of a 3 hp vintage (say mid-late 60's) briggs and stratton motor (complete) is the same as a 2hp same era briggs. Is outside same or is 2 hp smaller or is it just internals that differ? If 2 hp is in fact smaller...
  9. Biffmini
    76 - 2hp briggs Help
    I did a search on the the #'s 60102 / 0301-01 /76111501 & hit a brick wall. I need a carb rebuild kit & or gaskets, maybe carb pivot arm & link rods, head gasket, & air filter for sure. I'd also like to loose the points, can I put a electric ign. - arm. mag on this? I'm a amateur engine guy I...
  10. J
    2hp briggs in NC
    2hp briggs motor not mine, but if someone wants it i might can help get it shipped
  11. thejoker
    2hp Tecumseh/Lauson engine
    So I just got this bad boy today. I've only seen two so far so I just had to get it. Unfortunately I can't find any info on it. Basically I wanted to show it off. Still not sure if I'm going to keep it or sell it yet.
  12. jackeo21
    2hp Briggs, Restoration
    Hi all, (sorry for all the threads :laugh:) Really wanted to do a thread on my 2hp. It's taken me a little over one week, to disassemble, clean and paint. This is the 30 dollar engine I brought at a swapmeet. For memory is a 73, 60102. It has a vaccujet carb. The motor is a copper colour, which...
  13. jackeo21
    2hp Briggs, Maybe...
    Hey all, Went to a swapmeet and car show today and picked up yet another motor. There were 3 briggs, but I think that this was the best of the 3. I was after a 2hp aswell, as they are rare in my country :laugh: But, it has an 8c 3hp head on it. I'm yet to determine what it actually is by...
  14. nigel
    scat cat jackshaft help
    i need a jackshaft kit for the scat cat. wich one is the one to get? for those of you who know the scat cat frame. thanks for any help
  15. Lauson-Tecumseh 2-2.5HP Air Fiilter Housings 3
  16. Lauson-Tecumseh 2-2.5HP Air Fiilter Housings 2
  17. Lauson-Tecumseh 2-2.5HP Air Fiilter Housings 1
  18. Doorman14
    Briggs 2HP Overhaul
    Hey Im new here and i was hoping i could get some help with an old briggs 2HP that i want to use for a minibike. The valves are completely covered in black stuff and i wasnt sure what to do to get it off. If anyone knows any good parts web sites please let me know about them. Thanks!
  19. nigel
    what is it?
    the blue one in background
  20. teste rosa
    teste rosa
    tractor and engine
