TIG will, under the right conditions, produce a stronger weld, but not hands down, IMLO. I find that it also has a couple of downsides. For instance a large fillet will always result in more warpage and stress than an arc rod and most certinally in comparison to a MIG. We're talking mild steel tube minibike frame here. You're right about a MIG or an arc welder is what should be purchased first. Preferably the arc welder. That way a person can also weld cast iron and stainless and hardface that will not be cheap to do with a wire feed.
