Its sounds like your getting a lean intermediate miss , or a fouled plug have you cked the plug , how I rough adjust a 334 is i start out with the low side about 1 1/2 turns out and the high side about one turn , I start the engine turn the low side in until the engine stumbles a little then bring it out till it evens out and then give it an extra quarter turn , then i go to the high side hold the rpm up to 2500-3000 turn the high side in till i get it to stumble and bring out till it evens out , let it go back to idle and see how it reacts , sometimes after balancing the high and the low You have to touch up the low side a little , and if the carb has a high pop off pressure of 15 or higher it will be a harder to adjust . If you get a chance pop on to EC carbs website go under important links and then go into technical info there are some good downloads on there how to set up Tillys hope it helps !
