im talking about old cars with the lever on the steering wheel to advance/retard ignition timing
Model T fords had a timer, which is similar to a distribuor. A lever on the left side of the column changed ignition timing, while a lever on the right operated the throttle. Moving the "spark" lever up retared the spark and moving it down advanced the spark by moving a rod attached to the timer cover, just like a distributor can turn or how you can change the position of your flywheel on your minibike. Cars with distributors had vaccum advance or used fly weights (mecanical advance). Modern car engines ignition timing are controlled by a computer. In a model T for starting, the spark lever needs too be retarded before turning it over or it can kick back and either break your arm (if hand cranking) or break the starter. After the engine starts, the spark should be advanced quickly before the engine stalls. On cars without an electric starter, if your trying to start the car by yourself, this means running to the drivers side of the car to pull the lever down before it stalls after your out of breath from cranking your :censure: off. Anyway, as far as making a setup like this for a small engine, there is probably a way you could rig the coil up so it travels on a rail of some sort above the flywheel. looking at the flywheel, the coil would slide the the right to be retarded or to the left to be advanced. It would allow you to pull start your engine with the ignition retarded then after it starts you could advance it for racing conditions. Probably hard to fabricate but a neat idea.
