if you frieght train the engines they are done like this
the front engine has a clutch the chain on that clutch goes back it a solid sprocket on the crank of the rear engine THEN outboard of that sprocket you mount another clutch and the chain from that goes to the rear wheel sprocket
this way you can start the front engine then just rev it up and its clutch will enguage and start the rear engine
the engines will be out of sync at first then auto sync based on clutch slipage and firing pulses
their are lots of ways to do it but i know for a fact this works
oh one more thing you will need to run one clutch with the sprocket inboard and the other clutch with the sprocket outboard
have fun
have fun
