Valve Springs and E tubes
vwfan79
I wanted to replace my stock valve springs to eliminate high rpm valve float. I talked to one of the techs at one of the performance companies an was told that the 18# springs aren't as good as everyone thinks and that I would be better off with the trick springs. He said the trick springs actually have more noise pressure then the 18# springs. I got the trick springs and seem to still get the float around 5800 rpms. I think I may be running a little lean so I'm going to up my main jet and see if that helps too.
I would like to get some input from others who have experience with these springs.
As for E tube, is it necessary to change them when you increase the main jet size? Can they be DIY modded?
rmm727
e-tube is for off idle to mid range. the right one will make your engine more responsive. most use the gx140 one. as for the springs, I wouldn't be surprised about the nose pressure. I bought some 10.8's to replace my 18s but never tried them. Don't think the 10.8s last as long though.
vwfan79
U will need a 140 tube for more torque.
To fully use ur new springs, u will need a cam to push them to higher limits
I have plenty of torque already, my bike pulls like a some of a bitch.
These springs are intended to be used with the stock cam, they are to give more nose pressure and still pass stock tech check. They are claimed to have more nose pressure then the 18# springs at stock cam lift.
rmm727
not sure about the etube as i don't use one my self, but if you dont have billet parts fw and rod then even 5800 rpms is pushin it
Are you running an older motor, can this be done on a clone and what advantages does it have?
I already answered your question about what the e-tube does prior to you posting this.
It does fit the clone. It is right above the main jet in the carb. Main jet holds it in.
vwfan79
Yup thanks, I think part of the problem was I was running lean, I redrilled my main jet and it runs alot better at the top end in the high RPM range. Springs are working great and there seems to not be any valve float, I may put in a 140 e tube and a smaller rear sprocket. That way I'll gain some top end and not loss any or little torque.
vwfan79
$7 for the chinese gx140 e-tube. Why bother trying to solder it?
Cause $7 is $7 and you have to pay shipping then wait for it to get there. It took about 20 minutes to solder it and I prefer DIY, I enjoy that kinda stuff. E tube soldered from a 5x5 to 3x3 and bike runs great.
rmm727
I like DIY too. Just sometimes, your time is worth more than what you can spend on the part. I also had concerns that the solder wouldn't lay down smooth enough and affect fuel flow.
vwfan79
I hear ya, but this was one I decided to try. I used a fine file and smoothed out the solder, looked pretty good and should effect fuel flow.
