The $40 SketchyTrike I picked up over the weekend has a Salsbury Corp. 500 Series driver clutch for its torque converter system. It is misbehaving (I think) and I'm not sure what I should do.
It seems to want to throw the movable sheave at the belt WAY too soon (like at startup/idle speed) causing the kart to take off without a rider. I have hooked a tach to the engine and it idles between 1500-1700 RPM - it's a Tec H50 - the idle "surges" but I suspect that will be resolved after I rebuild the carb. Parts are on the way.
If I try to slow the engine down enough that the clutch stays disengaged (1100-1200 RPM), the engine won't stay running. That's a lower idle than factory spec anyway, I assume.
I did a little internet research and it seems that Comet took over production at one point and this became the Comet 500 series, as shown in this diagram:
I did find some parts for it here:
Comet 500 Series Torque Converter System (Symmetrical) for Go Karts & Mini Bikes | Go Kart & Mini Bike Parts | MFG Supply
However, there are too many options for the weights etc. and I don't understand which ones I may need to purchase in order to get the clutch to engage at a higher RPM.
Am I correct to guess that I should have the 302290A Green spring kit, plus the 300157A roller kit, in order to obtain an engagement speed of 1800 RPM (just above idle)?
I really don't want to dump a whole bunch of money into this project because it's just something dumb/funny to tool around on. But if someone knows how I might make the clutch behave the way I want it to, it might be safe(r) to drive.
