What horsepower? PICS incl.
I have a briggs and want to know horsepower got any ideas?
model is 130202
type is 0209-03
code is 7205097
Thanks
FRANK
72 Briggs 5 horse.. Thats what the shroud says anyways.. From the looks of things it probably belongs on the engine so it's most likely correct.. Either way, from like 69 to 89 they are all essentially the same engine. Hella good motors.. :thumbsup:
Man, I'm batting a 1000 :doah: All I got right was the year, but hey, I'm learning.
http://www.outdoordistributors.com/Briggs_And_Stratton/briggsmodelid.html
Briggs & Stratton Numerical Designation System
Example: Model
303447 Type
1234-01 DateCode
01061201
This chart explains the numerical model designation system.
FIRST DIGIT
AFTER DISPLACEMENT SECOND DIGIT
AFTER DISPLACEMENT THIRD DIGIT
AFTER DISPLACEMENT FOURTH DIGIT
AFTER DISPLACEMENT
A B C D E
CUBIC INCH
DIS-
PLACEMENT BASIC
DESIGN SERIES CRANKSHAFT
ORIENTATION PTO BEARING,
REDUCTION GEAR,
AUXILIARY DRIVE,
LUBRICATION TYPE OF STARTER
44
46
A to Z
0 to 4 -
Horizontal Shaft
5 to 9 -
Vertical Shaft
A to G -
Horizontal Shaft
H to Z -
Vertical Shaft
0 -
Plain Bearing/DU
Non-Flange Mount
1 -
Plain Bearing
Flange Mounting
2 -
Sleeve Bearing
Flange Mounting
Splash Lube
3 -
Ball Bearing
Flange Mounting
Splash Lube
4 -
Ball Bearing
Flange Mounting
Pressure Lubrication
on Horizontal Shaft
5 -
Plain Bearing
Gear Reduction
(6 to 1) CW Rotation
Flange Mounting
6 -
Plain Bearing
Gear Reduction
(6 to 1) CCW Rotation
7 -
Plain Bearing
on Vertical Shaft
8 -
Plain Bearing
Auxiliary Drive (PTO)
Perpendicular to
Crankshaft
9 -
Plain Bearing
Auxiliary Drive
Parallel to Crankshaft
0 -
Without Starter
1 -
Rope Starter
2 -
Rewind Starter
3 -
Electric Starter Only
110 Volt Gear Drive
4 -
Electric Starter/110
Volt Gear Drive
with Alternator
5 -
12 Volt Gear Drive
6 -
Alternator Only
7 -
Electric Starter
12 Volt Gear Drive
With Alternator
8 -
Vertical Pull Starter
or Side Pull Starter
9 -
Mechanical Starter
A -
Electric Starter/12
Volt Gear Drive with
Alternator & Inverter
Example - To identify Model 303447:
30 Cubic Inch 3
Design Series 3 4
Horizontal Crankshaft 4
Ball Bearing
Flange Mounting
Pressure Lubrication 7
Electric Starter
12 Volt Gear Drive
With Alternator
TYPE 1234-01, The type number identifies the engines mechanical parts, color of paint, decals, governed speed, and Original Equipment Manufacturer.
The code number identifies the assembly date of the engine. In some instances it is necessary to know the code number as well as the model and type number when performing adjustments, repairs or ordering replacement parts for an engine. Here is how it works:
CODE 01061201, The code is the manufacturing date and is read as follows:
01
YEAR 06
MONTH 12
DAY 01
ASSEMBLY LINE AND MANUFACTURING PLANT
Thank u Thank you
U guys really know this stuff.
this is why I got involved in this game it's something that looks a lot eaiser than the cars I play with !!!
FRANK
