So, if you have seen my last post, im getting a scratch and dent green baja minibike from that guy in phoenix for $150. What I want to know is when I get it should I immediately drain the factory oil out and replace it? The engines have only been started maybe twice and never broken in, some may have never been started except at the factory when they were tested. But I heard its best to leave the original oil in until breakin then change it in a certain amount of hours? Well if I change it what oil would you recommend to replace it with, and what weight?
So the nut-shell of this is:
1. Should I leave the factory oil in for break-in or not?
2. If you guys think I should use a different oil for break in what type do you think would be best?
3. And what weight of oil should I use
(Winter here is about 85* during the day and like 40* at night,)
