That would work but I found some rod ends and made the panhard rod. I had to grind down the spring quite a bit to get some flex out of it. Its stil pretty stiff I might do some more. and the back is too soft so iv got to adjust the shocks and if thats not enough ill have to move the mounts again. I got the steering all done aswell as the exhaust and foot pegs. The muffler points straight down and its kinda small so itll probably be a bit restrictive but it fits nice and nothing is in the way of anything. I also got the gas tank mounted no pics of that yet but its a small predator 79cc tank mounted at the upper back and i cut a hole in the hood for the cap. It mounts to the engine so when i remove the hood i dont have to mess with the tank. Im probably going to mount the battery at the front either directly infront of the starter or ahead of the steering shaft directly on the inside of the hood. Im starting to think about the wiring and gauges because that will be next. Then ill figure out the gas and brake pedal and itll be pretty much done with the major work
