This is my 2018 build off tractor. I will be using the wheel horse body and an 18hp kawasaki vertical shaft engine converted to horizontal. The chassis will be 1x2 tubing. full suspension the back will have a swing arm combined with jackshaft. Im going to use a belt drive centrifical clutch to the jackshaft and chain back to the 3/4" straight axle. If that doesnt work i will put a sprocket on the belt clutch and use it that way. Im also going to leave room for a 40 series torque converter if i should decide to go with one but there will likely be tire interference. the steering wheel will be hood mounted so i have to keep the engine far back. The front end will be like a hot rod with leaf spring suspension. The fuel tank will either be at the front like a gasser or just under the hood at the back. I got the frame started today and the jackshaft drilled in. I will probably have to make some wheelie bars for this thing but I will be using it mainly offroad thus the suspension.
