Who's got kickstand woes?
Minimichael
Thanks @sparkwizard for noticing. :scooter:
But the marking and drilling tested my patience more than the cutting did. And like I said I'm trying to control the quality (or not) by at least staying consistent. The prototype took a lot of tinkering to get it dialed in, so I'm hoping repetition helps these ones go quicker.
Plus, I really love my portable bandsaw which makes pretty easy work of the freehand cuts.
And just wait til the hammering starts on these. Talk about tedium. o_O
That bandsaw cuts a lot of the noise, too. I had assumed you were using a reciprocating saw.
You don't have a press, do you? welding up couple of jigs from angle iron and pressing your brackets might be fun.
Nice work
Minimichael
I'm so bout the Lime Green Flyin thingy now! :cool:
Lol :D
I've noticed over the years that my garage seems to be a pilgrimage destination for kinda unique bugs. Like every spring this huge black ant with a couple smaller body guards comes marching in and inspects the place for a day or two. Walks into the garage; walks out; then comes back later. A praying mantis usually comes for a few nights, too.
Minimichael
The first bends are begun as of last night. I figured some heat might help, but that still didn't allow the vise to completely squish the fold flat. I'll have to hammer them next, to close the last 1/8 inch or so. You might notice I tried to encourage the cut ends to flare outward during the squishing. I also changed my choice of pliers and found the vise grips worked best for that. (Fourth time's a charm I guess.) Pretty sure the accidental drill hole on that final bracket also helped it flare better. (Live and learn.) I'll just have to beat the others until they start looking more like their perfect sibling.
Minimichael
Not all of the backing tabs' first folds folded real square. One of them did. But the others were off a sliver or so, so I was able to adjust them by laying the whole piece onto the blade and just wait patiently for it to get from the outside to inside. Damn I love this saw. If you're doing a lot of cutting with portable jigsaws, a portable bandsaw should be your next saw. Just sayin ;)
So hammering's next, but I adjusted some edges and bends. Just taking my time here. And my old vise jaws are trashed so I'm thinking about replacing them before any more bending. But hammering's next.
Minimichael
The reinforced pivot tabs are hammered flat enough now that the kickstand clevis fits nicely and may even have enough room in there for a spring washer for smoother operation...once I get a lot further.
Filing the circle shapes went smoothly, after I bent the rear adjust tabs back out of the way. Not sure yet where their final positions will be.
Next, I have to bend the front cover tabs into place, which may be tricky because I'm already running out of ways to grip these in the vise.
Minimichael
My vise jaws' edges are not smooth, so some stand-ins with better profiles helped me get the bends I'm after. Here are some pics of how I got the frontmost tab into place.
To stay consistent, I'm trying to keep hammer blows to a minimum. And while some seem to call for sharper hits with precise shapes, others want more forgiving pummels, like from a rubber mallet. I also found that putting an intermediate hammer into position against the piece and then hammering just the intermediary really cut down on mistakes. So, I used my square-faced shaping hammer for harsher strikes, driven with a ball pien; and for the softer, bigger bends, I fronted with the rubber mallet, driven by a dead-blow hammer.
It's surprising to me how clean and uniform these have remained.
Next comes cutting though.
Minimichael
So here's a tip..
If you're tapping threaded holes through 10ga. steel and you want a nice tight thread grip on your 5/16-18 screw, do it with a 5/16-17 tap. You shouldn't go all the way through (so maybe it's really getting your thread lines started with the 17), but then you get your screw and carefully force that the rest of the way through. So I guess this is really form tapping now that I think about it. Anyway, I'm working with mild steel and it's working well so far. I'm also glad I'm practicing these...
Minimichael
With all the folding and bending done, it's time to trim some excess off the tops to match the prototype. You can check my video to see how the band saw and a single drag cut helps me keep the line straight and clean.
Coming up soon: drilling the main hole.
https://youtube.com/shorts/VFUz2LLnybg?si=oG2uw4RV34XCzjja
Minimichael
Oh, and you might want to forget my advice on using a 5/16-17 tap for an 5/16-18 set screw. While it did stand in for a proper sized tap, so would a proper tap. Still, I say tap with just the tip and then let the stud finish the hole for a nice friction fit on your set screw.
