why do people shave the pto shaft?
So i'm getting around to firing up my 4 hp and I noticed that the pto shaft is shaved and has no keyway....it has a threaded hole in the shaft, which is something i havent seen with my smaller briggs engines.
Why on earth would someone do this to the shaft and ruin it for a clutch? Can I still run a clutch on this engine or am i wasting my money buying parts for it?
shaved into a taper.....it has no keyway. im confused as to if this was from factory like this(no keyway). the taper is DEFINITELY not factory done.....tool marks all over it
CLH
Some engines came with a female threaded hole in the end - some didn't. Just depends on how the manufacturer of whatever XYZ product needed the shaft to be to work for their application. The cast iron Tecumseh 7hp I have didn't have a threaded hole in the end and I had to take it to the machine shop to have it drilled larger and tapped out. The hole was there on the end - but inside of it were no threads which was incredibly odd/inconvenient.
what are my options to get this shaft in order to be used on a mini bike
CLH
If your shaft is tapered with no keyway I wouldn't bother trying to fit it to a minibike. There are adapters that fit onto tapered shaft to make them non-tapered, but those atleast require a keyway. You can try swapping out crankshafts from a parts motor, but thats a good amount of work and you have to worry about the interchangeability of seals/bearings and if the flywheel will fit when you start swapping out crankshafts. It will be cheaper/easier to find a different engine that has the correct shaft.
If you're really in love with that engine, a machine shop could eliminate the taper and cut in a keyway. I think most would agree, the cost would outweigh the value of the end result.
I would have to check the total indicated run-out at the future clutch location on the crankshaft before anything. If its bent or otherwise worn, it might be a parts engine. That crankshaft has had a tough life so far. If its good, I would cut and weld, or take it out, cut a keyway and tap the end for a clutch.
SAT
That's a brilliant answer! I love it. That's what i shall do! Weld it on. BINGO! [MENTION=13654]gumpit[/MENTION]
Just make sure you weld it on straight with a taper it will be easy to get it crooked
the shaft on this one is straight no taper. It is threaded and has no key way. I'm almost positive at this point it is idiot proof. But I've been wrong before. I will double check everything before i weld it. Thanks for the heads up. Trent
65ShelbyClone
Because they're hacks without the means to do things right. That's all I can think of.
Depends on whether the shaft is close to a standard size. I'm leaning more toward "waste of money" than anything else.
#18
Wow! Wondering why he didn't give his opinions when those post were made in December 2017. Numb from the neck up??? Lmao!!!! I have a low tolerance for stupidity!!!! smh!
I’m sure you will be fine, I was referring to the OP
