Thread hijack back to Coleman lanterns;
So, OldSchool, I have a 242 and a 220 that I want to get running. The 242 needs a generator and some cleaning, the 220 needs a generator and glass and cleaning. Do you suggest staying with the generators Coleman suggests, or ones from different models?
They still make the T66 and T44 for those lanterns.
AS long as you are goin to run camping fuel then you fine.
The part numbers have changed not sure what the new equiv number is but I am sure you can buy new replacements.
Now if you goal is to do a kerosene conversion ( this is very popular because the they burn less fuel and generaly work better, trad off is you need to take the gen a part and clean it every 10 tanks of fuel with something like bore cleaning solvent fro gun to remove the carbon deposits that cloge them up ).
In many cases you can clean a generator.
Are these lanterns still functional or completely plugged up?
If you can get the spring and packing out to clean them I would try that first. If the inner working will not come out remove the gas tip with a small creseant wrench and hewat the gen up untill its dull red and drop it in a pail of water. The shock will usualy casue the now burned carbon to crack and makin it easier to clean. Odds are this has caused the paper like pacing inside to fall a part. Replace this as per my other video in this thread.
Use the 201 generator ( modern replacement for the TK66 ) in 242 and use the gas tip from a T66 in the T44 ( thus you have created the now impossible to find TK66 for the export kersene 2 mantle lantern ) In both cases you will also need the preheat cup or make one from a copper pipe cap to hold your preheat fuel.
This is the Canadian 1947 157 table lamp ( yes you read that correctly this is a lamp for inside your home ).
I modified it for K1.
It looks different from your American 220 lantern but they share many components ( like the T44 gen ). In this case I used the #6 gas tip and replaced the factory spring and asbestos packing with with some copper shielding tape ( sort of a fine knit copper fabric, I can mail you some if you feel you need to do this mod )
157 Kerosene test run - YouTube
These are the best mantles you can buy because they are Thorium ( do not eat mildly radio active unlike the current Coleman ones that are just poison )
The big ones are for your 242, the smaller for the 220
PEERLESS MANTLES 20 PER LOT FOR PRESSURE LANTERNS AND LAMPS SUCH AS COLEMAN | eBay
PEERLESS CLASSIC MANTLE LOT OF 20 FOR COLEMAN STYLE LANTERNS AND LAMPS NEW | eBay
I am trying to put too much information into this reply.
If confused send me a PM
