Thanks Markus. I am still looking for a crank for the H35 (green 1971 Rupp Scrambler) and considering other options.
Bill T
If your really dead set for the H35 and willing to loose the HS40 as an engine (not many people are willing to do this) you can use a late model H35 block and transfer your early hS40 crank, sidecover, and flywheel/ignition over, if its a lighted/charging coil flywheel you will need to use the shroud from the HS as well because it has to have the studs for the recoil). As of 1983/84 they "stroked" the H35 matching the HS engines. and some of them even used the same crankshaft that the HS40 used at that time and got the larger HS rods as well. still use the H35 cam, lifters etc..
the 34755 a and b blocks were like that and you would want to find one of those if you could as the casting is still fairly smooth enough that when painted they still retain the 1970's look. Plus they still used the larger exhaust valve. They discontinued that block though while they were still in business and offered the 36562 as an alternative which by that time was used on their H30/H35/ and H40 engines till the end. it has the smaller exhaust valve (usually comes with it) and the casting is usually very rough as tec quit painting engine blocks by that time so it may not smooth out under paint too easy and be noticeable. also the later the block they usually are not drilled and tapped for the magneto so that will have to be done as well (pretty sure its that way on the 36562) They are dimpled though in the correct spot.
If you were to do this, set the timing same as an HS engine not what the H was. I have mocked up/fitted parts to verify, but I have never pulled the trigger on a finished build so I don't know how well they run. was going to but the early HS parts are needed around here right now. The later engines run better than the earlier ones, but they also have 2 more pounds of flywheel on them.
