Now that's a great suggestion for any rebuild of a vintage Briggs engine. Only caution is to make sure the starter cover is reinstalled securely (and evenly).
True, I would hope everyone rebuilds and lubes the starter pawl during a rebuild. Daniel has his apart after all.
My point was that with a high RPM engine, you end up doing it again. And again. Those pawls do not like high RPM. Case in point, last raptor that went on my Tote Gote. I installed a cleaned pawl, even replaced a couple of the balls because they had some flat spots. Lubed with 30wt. Two hours of run time later, there is that squeal. I left it alone, it wasn't that loud. Next time I started it, it was louder.
Pulled the shroud, pulled the pawl, nothing wrong. Installed a new pawl, lubed it. Same thing a couple hours later. Pulled it, lubed it, all is well. This is the second high RPM flathead design that has done this. The other flatheads from 2.5 to 5HP I rebuilt and lubed them once, and never had a problem, running them on the governor. It is an issue with high RPM flatheads using the recoil start system.
