Most are singles because there were more people with electricity when the twins came out in 1937. It's throttle governed and it is one speed until I fit a carb to it.
So is that empty part in the middle where you put clothes to be washed. Seems kinda small like maybe one sock at a time small. Definitely looks cool on there.
That is great, thanks! Both cylinders fire at the same time, obviously.
Fitting a carburetor has got to be challenging, too. They sit on top of a cast iron fuel tank, right?
That grey knob is fuel/air?
Yes, the base is the fuel tank. The knob is just to let air in. The fuel is sucked up through a jet and into a port in the crankshaft and disperses into the crankcase out a hole in one of the crank flywheels. The governor is inside the flywheel also and is adjusted by removing a pipe plug in the top and using a screwdriver to screw the governor up or down blocking the fuel passage more or less. If I put a regular carb onto the air pipe I would need to plug the fuel jet and draw the mix from a different location on the tank cover. Also with a carb doing all the metering I would remove the governor. I would also need to add a pulse fuel pump or put an overhead tank to gravity feed. It's not real complicated, just a lot of work. So for now I'll just set the governor to a high speed and use the clutch to start and stop. Another possibility to add some performance is to attach a lever operated cable to the plate the points are mounted so you can advance the timing on the fly. It's turning out to be more of a project than anticipated. I love it.
Thats things Sweet! I made a Briggs Model FH scooter that I need to re think out somewhat. Yah its chalangeing to get things to work right at first & gets quite involved rather quickley but thats how it goes. Ive seen one other 2cyl whizzer like bike, Its the Monark Super Twin. It Has a Power Products engine core the same as a P.p 300...
