5/8
  1. A
    Coleman CT200U 5/8" shaft TAV install
    Just completed a Chinese TAV install on a Coleman CT200U with a 5/8" crankshaft. Some say it can't be done, but I did it.
  2. B
    Hisun 5/8 crank swap
    Will pred 212 3/4 crankshaft fit the hisun 196cc engine is on Coleman ct200u if that matters
  3. cambo61
    F/S (2) Go Power 6" aluminum 5/8" shaft front wheels
    I've had these restored pieces too long and it's time to let them go. I want $90 + ins/ship each which is more than fair considering they are fully restored. Ships from (32952). These were disassembled, blasted, and powdercoated with a very close high gloss gold. New 5/8' bearings and new...
  4. Coleman CT100U tav
    Coleman CT100U tav
    Coleman CT100 tav, CVT, torque converter
  5. Coleman CT100U chain guard mod
  6. Coleman CT100U chain guard bracket
  7. Woody212
    2 speed engine clutch 5/8" shaft
    Rebuilding a Super 2 Speed and need the engine clutch. Not pick on brand/style. Thanks
  8. B
    5/8 Axle spacers
    Looking for miscellaneous 5/8" axle spacers. Thanks Bryce
  9. trailramdan
    5/8 clutch
    Helping my nephew build his first bike we are looking for a clutch for his 79cc predator engine
  10. M
    5/8 clutch on the cheap?
    looking throw together a beater, anyone have chain and a 5/8 they don't play on using the want to donate or sell cheap
  11. capguncowboy
    NOS Rupp clutch drum (5/8" #35 13T ) Scrambler Sprint
    This is an NOS clutch drum, still in the packaging. It was opened for pictures and to confirm the inner diameter of 5/8". 13T $50 obo shipped
  12. C
    Columbia clutch 5/8" bore size nos
    Columbia clutch 5/8" bore size nos with some shelf wear $40 located in Wilkes barre pa PayPal or in person
  13. Valocalrep
    5/8 bicycle clutch
    Looking for a clucth to throw on a small 5/8 shaft for a side project im doing it needs to be something like this, Centrifugal Clutch For Bicycle Chain 410, 415 - Off Road and Racing Go-Kart Parts Online
  14. Doodads
    5/8 two speed clutch
    As stated, looking for a two speed/two sprocket centrifugal clutch for 5/8 shaft. Yes, new are available but I've only found one source and it's twice the price of 3/4. Longing for a 2 speed but may change from 3hp side pooper to 5hp 3/4 shaft for economics in driveline. PM responses please...
  15. trinik7597
    Hardly used 5/8 max torque
    Hardly used 5/8 35 pitch max torque clutch $23 shipped
  16. Danny01
    97cc 5/8" clutch... need gone!
    I have the original clutch that came on the 97cc engine... I believe it is a 5/8" bore... it's an 11tooth, 35chain... the teeth on the sprocket are all intact... please pm me!
  17. nds1968
    Adjustable 5/8" Weld On Jackshaft Kit #35 Chain
    Looking for an Adjustable 5/8" Weld On Jackshaft Kit #35 Chain like or similar to the one OldMiniBikes sells https://www.OldMiniBikes.com/Adjustable-Jackshaft-Kit-35-13T-18T-Lock-Collars-Key-Stock-Weld-On.html I'm just checking to see if someone purchased one that they never or don't need before I go...
  18. Robmus18
    Are the bearings in doodlebugs 5/8?
    That's my question, are the bearings in doodlebugs 5/8
  19. J
    WANTED: 40/41 TAV 5/8 drive sprocket!!
    I need a TAV sprocket for a go kart. must be 40/41 chain. Dont really care how many teeth just needs to be good useable shape. doesnt even have to be new. they are 12 on ebay. hoping someone has a spare they dont need they can let me get cheap. Let me know asap thanks!!!
  20. Sinner70
    5/8 bearing down to 3/8
    Hey gang, I got a nice Fox Sprite recently and am starting to put it together. I do not like the wheels it came with and was going to swap them out. I noticed the forks are drilled for a 3/8 axle. Is this stock? What is the easiest way to put on my wheels (Astro rims with 5/8 bearings) I think...
