Has anyone ever relocated the spark plug to a more centered location in the head? I have seen on other model B/S the plugs are in different locations in the head.
You are looking at an El Burro minibike. It was made in Michigan, I assume back in the 70's. I got it from the son of the original owner at Thanksgiving time. It had an 8 HP Briggs engine that had been converted to rope start and that seemed a little tired. I removed that and installed a very...
hey guys..
I have a 3.5 (older ) b/s horizontal shaft engine.
it starts with ether but dies shortly after..
I replaced the side gasket and the gasket under and between the tank and carb to no avail..
can anyone give me some advice on getting this carb straightened out ...
thank you
hey guys..
I replaced the side gasket and the gasket under between the tank and carb to no avail..
thank you
