Hello these wheels where on a mini bike I just purchased and had them bead plasted. They where on the minibike (grand prix frame??? :shrug: )in the picture ya they where ugly had like 10 coats of paint. But I'm not sure if I want to use them or if there original to the bike. At first it look...
I am just completing a mini bike build , and realized my old briggs flat head recoil,rope, assembly is a different bolt pattern then the briggs Raptor 1. The raptor is a new old stock motor and did not come with recoil starter. I installed a new recoil clutch but just assumed that it had the...
Just swaped out my old 3horse Tecumseh for a 6horse predator. Chain keeps coming off when under stress of acceleration and also when just cruising. Tried pulling all slack out but is still happening. Broke 2 master links, I finally just welded chain and made master link unnecessary. Chain still...
Hello im ne to the forum but i figured maybe there someone out here that could help me. I have a 212 predator that has been working quite well for the past few weeks. but recently i put a new header and air filter on it. After re-jetting the carb it wouldnt start. After taking it up to my uncles...
Hey everyone well I have a mini bike kit from gokartusa.com 8 inch wheels and a 6hp Subaru engine from a friend. Any ideas on suspension and foot pegs moved back. Thanks!
I have this mini bike frame. I think its an Azusa. Correct me if I'm wrong. Anyway, I've pretty much gotten everything figured out (thanks guy at the swap meet today!!) except the brake system I need. I'm not sure what size brakes I need. Can anyone help??
I've got a .750 bore raptor carb that I'm having some trouble tuning. It hesitates when I first take off but is great after I get going at full throttle. It sounds like the motor has more though. It feels like it should be getting more rpms. It's a gas carb,the metering holes have been slotted I...
Hey all new guy here needing some help
I bought a Deckson Dasher today for $100 (good price?) it's in pretty good shape and just needs a tune and a chain.
So that's my problem, I need to know what size chains these take?
Thanks!
I am in the process of cleaning up my original 69 sprint. When I removed the swing arm I noticed that the pivot bushing is froze to the swing arm. This does not seem right to me. Isn't it supposed to stay anchored in place by the end bolts so the swing arm can move up and down??? Someone please...
Hello, everyone. I resently bought a 1976 Briggs 5hp motor off craigslist for 25
Bucks!! It turned over good and looks well taken care off. I found that the intake valve was stuck but it had rusted stuck. So I got it out and cleaned it all up. Bought two new valves intsalled them, changed...
I put my new ss valves in my head last week but have seen photos of other peoples assembled and they dont look anything like mine can some one tell what iv done wrong. ps dont have the special valve spring compressor so it was hard to even get them like i did.
i have a newer 3.5 hp tecumseh no spark, the magneto is good, but its creating no spark, the intake valve was stuck but i got it unstuck and works good now but no sparka and wont turn over, could it be the valve or flywheel?? help
I have a 6.5 clone that I just removed the governor and put 18 lb springs....it turns on but after a couple seconds will turn off what can it be???any ideas??
Ok, bought a baja warrior, no spark. Replaced coil. Good spark. Cleaned the carb and tank, still wont run. It will sputter for a sec and die. Im SURE the linkage on the carb is wrong. Can anyone direct me to a link of a diagram of the linkage? Thanks!
Alright guys, I've got what I'm pretty sure is a fox thunderbolt and I can't find new brakes for the life of me. I bought some 4 1/4" brakes but they're nowhere near that size now that I have them in hand. Here's some pics and measurements.
The outer case is 4 1/4" wide.
Across the brake...
Hey guys. Looking for a #41 sprocket for my project. I need something around 35 to 40 teeth. I have been searching to no avail. Mounting is not an issue, as I will get the correct hub to match:confused:
Ok....first off...thanks so much for all your help you guys!!! Again...I'm very new at mini bikes and I'm sure this is a stupid question. I'm installing a new throttle cable on my Cat. When I twist the throttle, it doesn't retract on the other end at the motor. I'm pretty sure I have too...
Guys i have a bird wren and the steering bushings are wore slap out so another member told me before what kind of bushings to get so i pulled it apart awhile ago and i need to know how the setup is supposed to go together when i pulled it apart it had a few washers in between the fork brackets...
I'm not a church going person. But I've heard of the power of prayer, Say something for, jpr95 Jimmy Judd's wife. Jimmy told me today she is still in a coma. Been in one since Wednesday afternoon...
