Hello, another question about my Blazer 2 Speed.
With a GoPowerSports 80cc throttle assembly kit, it itself works, all parts, with a returning throttle. however, the governor assembly does not activate the throttle. In the reddit comments of my video here, https://www.reddit.com/r/Fixxit/comments/15p7v77 , they say that if it was on it would be fixed, but it is not, it is an issue with the spring present. Furthermore, even manually actuating the throttle directly on the carb by hand results in no acceleration and a very sluggish response. And finally, I believe all of these issues may be in part because I do not believe the belt drive is catching the belt drive on the crankshaft. All it does is rotate under the belt and smokes after the engine has been turned off. however, all these parts worked fine with the old Clipper engine it had on it before. But that was on its last legs and i cannot repair it. If any help could be given on these three issues, i would appreciate it.
Because I saw the posting about governor stuff and proper safety precautions resulting in a ban, This IS on a stock, governed engine.
