I have a fully built clone just replaced fuel pump because the other one had a leak. Used to start in a few pulls, pull started it right after its compression stroke and now it doesnt start at all, but has compression and spark. I pull start it right after its compression stroke to just right before the next one before the snap back... i have a genuine v26mm mikuni and the carb spits out gas randomly when i pull start it ( carb farts ). However i hear some denotation from the xhaust and carb from time to time as well. There was also some smoke coming from the carb some light smoke perhaps burnt gas... I have played with the air/fuel mixture from half a turn all the way out to 2.5 turns and can't seem to start it. Seems odd because it was running perfectly just before i replaced the fuel pump and cable to the mikuni. any help is greatly appreciated... :doah:
would an electric starter fix this problem?
