Hi Guys... I have a 1970 Briggs 5 hp serial number 130202 0307-01 7001297. On the original parts list it has the part number for the original coil as 298316.
Poking around the site you guys talk about a Magnetron coil part number 397358 being used on these engines and eliminating the need for points and condenser! Sounds good to me.. I go onto evilbay and see many with this part number ranging from around $18-50.
My question is are ALL coils with part number 397358 for pointless use? Are they all pretty much the same regardless of price or should I only get one that's listed as Magnetron 397358?? I know you guys know the best or hot setup on Briggs better than I do..
Sounds like all I need to do is clean up my flywheel real good, mount the new coil, set the air gap, snip the wire from the existing points to the old coil and that's that?
Let me know if I have my numbers right and if what I am thinking makes sense !!
ut:
Thanks...
Thanks...
