How I learned the hard way
My boss at the mower shop gets a snowmobile dropped off for repair. I am 15 and quite unknowledgable."I am now 51" anyways this twin cylinder 2 stroke snowmobile engine sat for about 2 years. I yank the rope and it "seems" to have good compression and great spark"cdi ignition" so I rebulid the single tillotson carb as my boss instructed. Put her all together and procede to pull the rope a bit...well it fires right up and then quits,After several rope yanks all it does is putter,mind you to me,the idiot on the end of the rope,the compression seems great,however...after sitting for so long the cylinders and rings were a bit rusty,after the initial fire up the rust fried the rings and compression dropped a bit. After a compression check,it had 60 lbs...both cylinders,we figured thats enough..not so...after a quick yank of the jugs,a mild deglaze,new rings and gaskets...that puppy had 155 lbs compression in each cylinder and ran great. Now over the years I have had a slew of 2 strokes come into my shop. And after initial checking of compression I develpoed these"rules of thumb" about compression. Yes it also has alot to do with displacement but in general,ya follow what I have learned and ya wont go wrong. As far as 4 strokes on small equipment,most of em got compression release mechanisims built into the cams,so ya gotta rotate em back wards to really get a good check. This is my 2 cents worth. It has worked for me and made many a happy customer. After all,re ringing a 2 or 4 stroke is not that hard as long as the cylinder is decent.
