Here's a update with a few questions.First ill post picts from my phone then ask the questions when I get on my comp.
Sent from my SAMSUNG-SGH-I527 using Tapatalk
I'm glad to being close to riding this thing and giving it to my cousins kid.I have a few questions about some of the work i have done today.
1)I ordered the wrong chain.I think i ordered a 40.Not sure if thats the amount of links or not but it seems like i need another 16".Is there the right chain available or do i connect 2 chains?
2)I hope i installed the throttle cable right.I did leave off the little nut at the ens so it would fit under the clamp on the engine.When i give it throttle while not running it has a short span of movement.Also it operates on when twisting it but it doesn't go back on its own,Almost like it is missing a spring.
3)The brakes seem ok but the cable seems to be a bit long.I had to move that black arm that the cable goes into back a bit.I did notice that the arm is bent naturally outwards which makes it off center fron the cables running line.Is this ok or should i take that ar off and flip it around?
Sorry for all the questions.This is my first build and i want to get it right so this young kid can ride it safely.
Thanks Rob.
