It is a black mamba jr but in his website you can get it with various lifts under the custom cam section, I got it as a 230 duration with .310 lift so I guess I am confusing people by saying it is a jr but it basically is with faster and higher lift ramps. For the 47 lb single springs I got from isky they are wider and require the spring pockets cut. I bought the cutter Isky sells then found it cut a 1 inch seat which was hitting some side protrusions in the head. I chucked it in the lathe and with a toolpost grinder narrowed the cutter from one inch to around .900 but I am going from memory and lately it is not too reliable.
