Hello everyone. I recently blew the original engine on my Baja warrior. I removed the flywheel, lighting coils and ignition coils. I want to know if the flywheel from the old engine will work on the new one. The current engine I am using is a power fist 212cc, and it appears to be similar to a...
Hello, I will be installing 26lbs springs in a non hemi predator and would like to know how can I measure the spring install height without any special tools? Thanks
Hello, I’m building a predator 212 non hemi and need advice on achieving a 10.5 to 1 compression ratio, how much should I shave the head? I haven’t measured how deep the piston is in the hole yet because I already took the whole engine apart and I’m waiting on my ring compressor and other parts...
How’s it going everyone! First post here although over many years I have looked to this forum for advise as I used to ride mini bikes,
Wasn’t sure on where to post but I think you group may help me the most. This motor is on a backwater mud motor kit instead of a Minibike frame, so turning a...
First thing I did when I got the Predator 212 engine was read the Warranty card, gave a maniacal laugh and threw it in the trash. Next I pulled the exhaust and intake and now they are hanging out with the Warranty card, he was getting lonely. Then I pulled the case cover and ripped out the...
I am I contact with a guy that has a Tote Goat for sale. He is asking $550. I know these can be a beast of a mini bike but is it worth all the hassle with the extra sprockets, bearings, chains and such or am I better off with say a Coleman CT200U-ex and do a predator 212 swap. I weigh 280 so I'm...
Hey there Im rebuilding my mini bike and I have a torque converter and I lost the bolt that goes into the engine shaft. know that the bolt is a 5/16 24 but i don't know how long it should be for a torque converter set up. Does anyone know?
What about using a tune pipe eXhaust on these motors?
Thanks .
I already bought aftermarket pipe and filter change. But You know that.
My question is for any info on tune pipes thx
Hello... Hoping someone here might know the answer and be able to help out... Just had my engine on my Coleman CT200U die off on me. Got a Predator 212 to put on it. But the drive shaft on the Predator is 3/4 inch while the drive shaft on the original Coleman engine is 5/8... I guess they built...
Any one see the new Ducar 212 replacement piston on the DynoCams web page? It looks like it is clearanced for the intake valve. If this is true and only $9 it might be a great budget upgrade for some people. It's a dished piston which is a little surprising. We might have a new part for out...
Hey whats up guys Ive been building a Azusa mini bike kit this summer and finally got it all done this weekend only for it to not start. Ok to start off I got a Hemi 212cc with governor removed, header, Mikuni carb, and air filter. When i was taking the oil sensor out of the inside of the engine...
