nope! Do it right one time! When you open the case for the rod install, you will see the other parts! You can knock the gear pin in the case from under the flywheel and remove the arm from the top of the case. I tap these 1/4-20 and plug them. You can also take the low oil sensor out at that time. Remember, the more you leave in there, the more that can go wrong!
