I have a non hemi that has developed some type of knock. Before the knock i had a hard time setting valve lash, but eventually got it. Went out and did a full pass to test it out and came back with a slight knock. took the head and pull start off and turned engine over slowly by hand and it sounds like and knock coming from crank or rod. I heard the knock when piston is at the bottom of the stroke. Could it be the rod? Just want to get some info before I tear it down tomorrow.
Mods are:
Ungoverned
Mod2 cam
Etube .32 jet
26lbs springs
Gx160 head
1.3 rockers
2 degree timing key
Should I put lash caps on?
Mods are:
Ungoverned
Mod2 cam
Etube .32 jet
26lbs springs
Gx160 head
1.3 rockers
2 degree timing key
