Putting together a small PTO bearing engine for my Lil Indian resto. I will be machining down a std. crank so I can use the ball bearing. The small Briggs bearing I got is shielded on one side and open (can see the bearing balls) on the other side. Which side of the bearing goes to the crank gear side? open or closed end of the bearing.
Thanks
Thanks
