I cleaned my carb with compressed air, cleaned the pick up tube, put some thin wire through the jet i used a feeler gauge and set my coil at .20 i believe, its thinner than a business card. changed the carb to tank gasket, carb to block gasket. I checked my diaphram and it looks fine. I am not sure what happened but the motor was running fine and then all of a sudden it wouldnt stay idling. it starts up fine, revs up fine and will stay running on as long as I keep giving it gas. thanks for the replies
