most of that setup will work on the newer briggs 5hp flip choke carb but the spring wont so you will need to rig up a return spring setup. iv seen pictures of it done. also the stock air filter will have to be removed and replaced by one that dosn't cover the new throttle arm. you should also put a billet flywheel and rod in that engine for saftey before you run it.
