B bryce05 Member Jun 8, 2016 #1 Jun 8, 2016 #1 Not familiar with Briggs , cans I use a 5hp carb and tank on a 3hp engine? Thanks
CarPlayLB Well-Known Member Jun 8, 2016 #4 Jun 8, 2016 #4 The tank support that bolts to the bottom of the block will be too long! Carb is the same
CarPlayLB Well-Known Member Jun 8, 2016 #6 Jun 8, 2016 #6 bryce05 said: I have the original 3ph tank Click to expand... just make sure the tank is the same depth. A lot of 3HP tanks were shallow!
B bryce05 Member Jun 8, 2016 #7 Jun 8, 2016 #7 I think it is a shallow tank. I have the original carb which is shot, can I take the tank tube from the 3hp and put it on the new carb?
CarPlayLB Well-Known Member Jun 8, 2016 #8 Jun 8, 2016 #8 bryce05 said: I think it is a shallow tank. I have the original carb which is shot, can I take the tank tube from the 3hp and put it on the new carb? Click to expand... Yes, but I dunno how to that! every time I have tried, I give up!
CarPlayLB Well-Known Member Jun 9, 2016 #11 Jun 9, 2016 #11 joshua. c. said: cut the existing tube to down size. Click to expand... I get that! How do you put the plastic strainer back on? I wrecked a couple trying! Easy to have sex with a rattlesnake than get those things on!
B bryce05 Member Jun 9, 2016 #13 Jun 9, 2016 #13 Thought of that but didn't know if that was a good idea
I izzyizz New Member Jun 9, 2016 #14 Jun 9, 2016 #14 Spray it with a cleaner first. Be easy mobing back and forth and squeeze it or it will. Crack its thin brass...
