5hp
  1. Dans1970Z20
    NOS New Briggs Raptor 3 in Briggs Motor Sports Tote 135230
    Finally got around to digging out my Raptor 3 engine crate, taking pictures and listing it on eBay. http://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_ff3=2&toolid=10001&campid=5335845805&icep_item=254988279427 Any questions let me know. Have decided I will never get to my Bonanza project...
  2. O
    Briggs & Stratton 5 HP
    No Longer Available.
  3. gwoods27
    5hp Piston ring question
    I’m looking for std rings for my 130202 5hp. Is 299742 the correct part# rings for it. Bore Diameter measures between 2.5615 and 2.5625. It’s an aluminum bore so I need chrome rings
  4. gwoods27
    Briggs 5hp Crank Bearing Question
    Ok...is this block worth using? If not is there any way to resurface the bearing? The Crank I'll be using is is good shape...just wondering if this will damage it?
  5. 5hp twister
    5hp twister
    5 hp twister
  6. 5hp twister
    5hp twister
    5 hp twister
  7. M
    Help Installing tecumseh 5hp on DB30
    My son and I have a DB30 with a 97cc engine on it. I have this motor and wanted to know what all is needed to install it on the DB30. Also I am unsure how to hook up the throttle, what is needed to hook up the throttle? The 5hp engine does not have a governor on it. Is this a good motor for the...
  8. Oldschoolcool
    5hp Briggs with TC, any fit issues?
    Are there any issues with mounting a torque convertor and interference with the rear mounted Briggs gas tank? Thanks!
  9. M
    Briggs 5hp tillotson
    I just got my first bike. It's a bonanza with a flathead and a tillotson carb I'm trying to figure out how to install my throttle linkage. I bought the ec lk-122 linkage I can't seem to get full throttle though. Also I'm using a single outlet mikuni fuel pump and when it's running I'm...
  10. CarPlayLB
    Edelbrock for Raptor/Briggs 5HP
    This is it! The last one I will ever make! This is an Edeblbrock head for the Blockzilla 1 that has been reworked to fit the Raptor and 5HP Briggs engines. Only for the cool kids! The holes were welded and re-drilled to fit. The mating surfaced was milled just enough to make it flat and clean it...
  11. CarPlayLB
    Briggs 3/4"NPT muffler NOS 5HP
    I have a new, old stock, B&S muffler, This fits the 5HP engines, or any engine that is 3/4"NPT. This is the good old heavy one and I am including the heavy "real deal" lock nut, not like the cheezy conduit nuts they use today. These vintage pieces can be yours for $22.00, priority shipped to the...
  12. Pasta
    5HP Briggs pops through carb
    Hi guys & gals. I've been away for a while but got back into my mini bike again recently. I have a little trouble hopefully someone can help me with. When I pull a hill, or throttle hard from idle, the engine pops through the carb. If I let off the throttle and ease into it, it will run...
  13. WrenchDad
    Coil question ,Briggs 5HP model 130202-0135
    Hi guys Currently I cant throw a spark I can feel a small current if I touch the lead while pulling but I cant get a spark to jump. I have cleaned the flywheel and bottom of the legs, I have changed the condenser ,cleaned and set the point but still nothing. I know the coil contact leg gap to...
  14. colt 1911
    Montgomery ward 1969 5hp
    located in stewartstown pa- $600- contact me for details- thanks jeff
  15. jaimenv
    BS 5HP pressure washer donor motor.
    Yes it is a scrap yard find. So far it looks good as a spare motor for one of my minis. There is a small blemish in the upper end of the cylinder yet you can still see original honing swirls on the cylinder walls. Best thing I like is the engine cover has bolt bosses for the pressure washer...
  16. R
    5hp briggs i/c engine
    5hp Briggs engine with cast iron bore. Came off a generator. Serial numbers date it to 1980s era. Pics available but can't seem to pot them on my phone. $125 shipped.
  17. S
    briggs 5hp governor linkage removal inside the case
    I have a old school 5 hp with the linkage arm rod going into the block do i need to remove the side case and remove the nylon gear off the cam and plug the hole or just leave it in with the outside arm off?.and run it....thanks
  18. Not so mini bike
    Old style Briggs 5hp recoil
    In good shape. Could probably be spun tighter to rewind better. Comes with mounting screw. $35 shipped
  19. 6doggie3
    5HP Briggs
    Hey guy's I picked up this motor for 50 bones at a modern go kart swap meet last week. I couldn't pass it up price with the pipe and manifold and carb but I'm not sure how to tell if it is a gas or alcohol motor? Thanks Michael
  20. 125ccCrazy
    Trade Briggs 5hp 325/330 lift cam for smaller cam
    Looking for a smaller lift cam for a build, somewhere between 250 and 290 lift...
