I have been building a mini for a while now, it's not for racing or anything. It's just for my enjoyment.
It has a 6.5 clone gx200 that I took the governor out, put an billet rod, 18lbs springs, custom exhaust, gx140 emulsion tube, 90 jet, and uni air flilter W/ adapter plate for the stock carb. I also put a 3 amp coil and a honda flywheel that has magnets for the coil.
On the frame; I installed a heavy duty motor mounting plate, tractor seat, suspension for the seat, gas tank, cigarette lighter outlet, headlight with low and high beams, battery, chain tensioner, 57 tooth rear sprocket and a hydraulic brake system for the rear wheel and a tail light/brake light.
pics will come soon!
