i used my dremel and a sanding barrel and with it being aluminum it really came out well and it screams:grind:
:thumbsup:
Realy screams eh?
There isn't much you can do to make these heads any worse.
But porting alone is not going to make a significant improvement.
Cencentrate on the short radious and around smooththe bowl around that guide. THATS IT.....
More will just mess up things and hurt you.
The stock airbox, and the phenolic base behind the carb and extremely retrictive.
The stock exhaust is best discribed as trying to eat when your constipated.
These things alone adressed will make a far more significant improvement than anything you can feel from porting alone.
As far as valve sprongs are concerned.
I can't comment on what you are using and if its a good fit or not.
BUT Honda G200 springs ARE the yellow 18 pound springs and as long as you don't exceed .275 lift they are the easiest way to raise the RPM range of the engine.
IF you don't replace the stock retainers, keepers and valves then inspect them regularly.
They don't last and will fail.
All your work will be wasted when the engine grenades after you drop a valve
