You can make it work if you raise the engine, that is what I did. You can buy some aluminum flatbar on ebay, cut it to the size of your engine's foot and then drill the appropriate holes. Worked great. I do not use mine anymore because I switched to a cent. clutch. I have a modified 6.5HP motor and the engine was just too much for the TAV30, belt was slipping.
